Discuss 96 Toyota Camry - no crank, no start in the Auto Electrician Forum area at ElectriciansForums.net
Hello, I have a 96 Camry - previously it started fine but the engine ran rough and when I scanned it it said there was a misfire in cylinder 4 (P0304). I changed the spark plugs (the old ones were all black with carbon) but no obvious improvement in the misfire. I was getting around to look into this in more detail when I went to start the car and.. nothing..
The dash lights come on. No crank... The odd thing is the door ajar light comes on and stays on flashing and making a 'tick-tock' noise. This stays on until I play about with the central locking or even open and close the hood, then it will switch off.
Can anyone tell me what they think could be going on here please? I have no idea. I did check the fuses and they look ok. Battery is new and I just recharged it. I didn't test the starter yet. Could it be an immobilizer problem? Looking at my drivers manual I can't see that it has an immobilizer...
Thanks for any advice members can give me...
Are you saying that it wants to try to start or turning the switch on and nothing?
Hi Megawatt - thanks for your reply. I turned the switch and nothing happened. But, this evening the same thing happened and I pressed some buttons on the aftermarket fob I have and the door ajar light went off and the car started. I think it must be some kind of immobilizer.
Sorted now - thanks
Sorted now - thanks
So Elliot you are go to go for right now ?
Reply to 96 Toyota Camry - no crank, no start in the Auto Electrician Forum area at ElectriciansForums.net
Hi there…I’m hoping that someone may be able to help me identify an electrical part of my ignition. For reference I have a 1964 Toyota FJ40 with a...
Driving on interstate at 70'ish and dash lights went haywire (check engine, oil change needed, tire pressure warning, etc) all started coming on...
Let me begin by saying by no means am i a car expert so please be patient with me. But i have a Ford 1995 explorer 4WD. The other day I parked and...
Hi don’t know if anyone can help. Starter motor for a countax ride on lawnmower K14 1992 briggs and Stratton vanguard 14hp engine 2 months ago...
6K
Hello, I’m not an electrician and I have a question in relation to Dimplex Duo300n. Some background information: a couple of months ago I have...
7K
