dingodeano
I will have a look at TeakDoor: The Thailand Forum
I thought neutral was looped to another board maybe? The main switch don't make any sense. I think it is a DP breaker looks like a C63They seem to have combined system within the CU E/N block at the top? then seperated after switch??
Its double pole it says N on back of box thus it must isolate a neutral bar where all white cables go, the L obviously is a plug on busbar rail.
Don't do it, you may end up with a ladyboy :38:
Never fitted square d. Plenty of merlin. Wouldn't you agree that the main switch looks like a double pole circuit breaker?
- - - Updated - - -
Don't knock it till you tried it. I've heard you can't tell. Could double up as apprentice I could do with an extra pair of hands!!!
As has already been mentioned its Schneider board but our version uses their other trade name Square D, these boards are standard square D range over here - the ones which just push fit into busbar (white mcbs overhere).
The only bit that may confuse you except colour coding is the fact the board is TNCS (Earth/N strapped together on earth bar) where as our TNCS is done within the service cutout.
It doesn't comply with BS7671 ........
Can't see how anything works, the phase conductors are not connected![]()
