Ok, a contactor works by energising a coil, and depending on whether its a N/O or N/C contactor it will make or break the contacts! The way you want to wire up the system is as follows! From the time clock for say HW take your S/L to the pump, from the pump take a S/L to terminal a1 and connect a2 to N! Connect Terminal 1 (top) to a P/L and terminal 2 (bottom) to the boiler. Do the same for the CH and you shouldn't get back feed through the boiler!
Hope this helps!
