Guest viewing is limited
SungiftSteve
Hi all
I'm here to help out with PV inverter & monitoring queries in the PV forum, i also build high end PC's so i might be able to help in the Computer/Network forum.
I am an I.T manager & field engineer for a South West based renewable energy installer/distributor called Sungift Solar. We install and distribute a wide range of renewable energy equipment ( PV/ST/Heat Pumps, Wind & biomass ).
I specialise in monitoring systems for the following manufacturers. Solaredge, Solarmax, SMA, Fronius, Eltek, Mastervolt, PowerOne & Resol. I also deal with a lot of aftermarket monitoring products ( Wattson's, GeoSolo's, PassiveSystems & SolarLog/SolarFox ). I also deal my fair share of inverter queries. I also I should point out i am NOT an electrician but if you have any questions on PV/monitoring i'll help as much as i can.
Cheers
Sungift Steve
SungiftSteve,
MarkieSparkie,
