Just checking if anyone has had the same issue with these? Pretty much on all of the bulkheads I've fitted since the middle of 2024, the led indicator which is normally green keeps going red after a few days/weeks. Removing and restoring the supply changes it back to green until it decides to change again. The instructions are of little help other than stating it indicates a defective battery, but that seems unlikely on all of them. Never had this issue before, not sure if it's normal or a faulty batch.
I used to avoid Ansell bulkheads at all costs they have terrible reliability.
There is a known issue with ansell with over 12 months. it concerns the self test types. they go into self test mode but do not automatically go out of self test and keep the red led on. Ansell are replacing the fitting free of charge. (at lest here in Ireland anyway)
Ah thanks, thought there must be some issue. Did you contact them direct?
