Discuss Any conlock converts on here? in the Commercial Electrical Advice area at ElectriciansForums.net
So do you just use standard conduit but use the Conlock fittings?
That’s what they were doing at THFC.
Not sure if the cut off the threaded ends or just pushed them into the fittings?
The thickness of the walls of conlock couplers and adapters is about the same as that of the boxes. Quite chunky compared to threaded couplers.
I bet that was never in the specification. Probably brought in as a labour saving excercise half-way throw due to the over run.
That and can then get a load of monkeys in with allen keys to wack conduit up.
Liberty.
I started there on the second of January this year.
They were using then and had been using it the year before.
From what I could tell, Imtech had been using it from the start.
I can understand the attraction of the speed and ease of installation, and having built many structures with Kee Klamp tube I can believe that Conlock will do the job up to a point. But no matter how well it does or doesn't work, it feels like a bodge because for nearly a century, pin-grip, lug-grip and other types of slip conduit fittings were considered unreliable for maintaining continuity and could not be used as a CPC. For cheap slip jobs there was also 'close joint' tube, i.e. unwelded, that obviously couldn't be threaded and didn't exclude moisture and air from the cables. Only domestic and budget commercial work ever specced slip conduit and many contracts specifically prohibited it, so any pin grip system would definitely seem like a corner-cutting exercise.
Seem like you could only use it for exposed installations then, surely all of the screw joints would have to be readily accessible to ensure earth continuity.
The company are advertising that it’s been used on some fairly major sites.
I doubt that periodic checking of the tightness of the grub screws has been factored in to any costings.
I also know that on one site, that many of the grub screws are or will be inaccessible.
I would imagine there are a lot lying on the floor too
Out of interest what size are the screws that hold this lot together ? Are they pointed ends ? Are they treated with threadloc or similar ?
It was used in a new build entertainment venue locally a few years ago.
Working on a few shows there I’ve seen a number of conduit joints which have fallen apart leaving the singles inside as the only thing holding up some parts of the conduit. They’ve probably been knocked a few times in the normal use of the installation, but they certainly didn’t stand up to it!
I can see it being ok for installations where the conduit is more decorative than functional, but not where actual mechanical strength is required
I'm curious why anyone would even use this. It's obviously not explosion proof or raintight, what purpose is rigid piping if not for those 2 purposes??
Mechanical strength.
Some customers only want the decorative effect of galvanised conduit in their oak barn garages etc , so the mechanical strength is not an issue as everything is fixed rigidly
I've mainly used conlock working down in Ireland. It is much much faster and easier to work with than normal conduit.
Makes fitting so much simpler. Doesn't matter if your cuts ends aren't perfectly square or if you're slightly off with your measurements as you have a couple mm inside your coupler / box.
No threading required just a small set/grub screw that needs to be tightened. As long as you make sure they are done up nice and tight it's very unlikely that the conduit will come apart.
The only experience I've had of it was in Dublin. It really takes the skill out of the job, but then most of the people i was working with barely had the ability to work out what cables were required for the circuit never mind putting up a simple piece of conduit. Don't think I'd ever use it myself, grub screw wouldn't be up to anywhere near as much abuse as a threaded joint.
What skill is there is cutting and threading pipe though?
Reply to Any conlock converts on here? in the Commercial Electrical Advice area at ElectriciansForums.net
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
Afternoon all! I was wondering if there were any electricians here who could share some knowledge please 🙏🏼. I have a Ninja dual zone air fryer...
Hi ive recently got myself a mig welder for my garage but each time i try to use it it trips out. Ive spoken to an electrician and he said its...
Hi, I've a 50A circuit (looks like 6 gauge wire - see image) that used to service an old hot tub and I want to convert it to 20A 12/2 to service a...
Good evening. Currently sorting out my girlfriend’s flat for rent. I’ve found all sorts of bad electrical work. Can anyone advise if this is an...
