Discuss Anyone know this screw ? in the Electrical Tools and Products area at ElectriciansForums.net
Ben87hall
As above, it's a security screw. Any decent set of security screwdriver bits will probably have one to suit.
System zero is the closest in design..But they tend to use a 6 rather than a 4 in this case pattern . Remove and replace with something easier to deal with ! whats it on ??
Reply to Anyone know this screw ? in the Electrical Tools and Products area at ElectriciansForums.net
Hello, Does anyone know of a Driver for led tape that can adjust the brightness on the driver itself by turning a screw etc ? Just need...
Does anyone know what this is found when removing old mirrored wardbrobes
Have an isolator switch with 20mm screwed entries into the bottom. Have existing 25mm conduit I want to run into it. Ideally I need a simple...
Thinking of getting a Runpotec XB300 cable dispenser, as my yellow framed tripod thing is unsatisfactory for all the usual reasons. You can...
I live in the UK and have a switch box that I'd like to replace, but it seems to have non-standard screws, closer to the center than what I can...
