G
gazzamikes
Just had text from a local restaurant I'm rewiring, he said when he flushed the toilet (saniflo) all the lights went out.
All of sudden it dawned on me what I've done, the owner wanted a dimmer so I changed switch for dimmer not thinking the fact the saniflo was on the lighting circuit, doh!
Anyone made any similar mistakes lately? I'm kicking myself for it
So what your saying they were put in darkness and the jobby is still floating :toilet:..... personally I wouldn't be putting the saniflo on a lighting circuit the motor could in itself trip a lighting mcb regardless of a dimmer been thrown in the circuit.
That's true, it divided into 4 circuits but unfortunately this one took out the lights in the darkest part of the building. Looking back it was a daft idea but it is a single toilet, the main customer ones are at the other end, still no excuse though!
just insist that he takes light meals in future
I didn't realise they had flush netties in Norwich. ;)
they're mostly surface mount.
Why has the dimmer made a difference as the saniflow is not controlled by the dimmer.
Am I being thick
So presumably you've fed the sani directly off the light which is switched through a dimmer? What happens when the light is switched off before the jobby is fully mashed?
That's correct wire puller, didn't even think! Popped out today to run new circuit and remove
Dimmer as it is now had it. Customer was understanding (and confused)
Maybe the owner thought the dimmer switch was to vary the speed of the saniflo depending on the jobby size?
So... Would that be fast speed for big jobs and slow speed for baby jobbies, or the other way round? What about density?
This could get complicated.
