If I've understood the question correctly, there will need to be two thermostats, one for upstairs to operate the upstairs zone valve, and another thermostat downstairs for the downstairs zone valve.
As far as I can see the Usense is a single zone (whole house) programmer and doesn't have 2 zone capability, but could be wrong!
Update: Apparently the Baxi Usense 2 can control 2 zones, but you need an additional thermostat and gateway. Buried in here:
Seems to be all done with wireless communication and setting it up in the app, but the hard wiring of the zone valves, which appears to be directly from the boiler, escapes me -so far - sorry!
Update: Apparently the Baxi Usense 2 can control 2 zones, but you need an additional thermostat and gateway. Seems buried in here:
The problem is the OP wants to use a Baxi Usense stat not sure if it is one stat for each heating zone or one stat for both unfortunately the information on the Usense stat and the gateway if needed is very limited, I suspect this might be one for Baxi tech support although from past experience a few customers with Baxi smart controls have asked me to install alternative smart heating controllers
Yes, It would be a thermo stat for upstairs heating and another for downstairs heating.
They just aren’t clear enough with the information, it’s straight forward if it was just
The wiring for two heating zones is described by John Ward below. It requires zone valves with the brown and orange wires for their microswitches.
I'm guessing, but don't know 🤔, that each Usense gateway "on/off mains switch" connections could provide the equivalent to thermostat terminals 1 and 3 shown in John Ward's diagram.
You’re absolutely right, I’m wanting one room stat for each zone.
After looking further into this I’m assuming the brown from the valve is what sits in this terminal, I’ve also emailed Baxi technical regarding a clearer picture. Just precautious with it stating to not connect 230v.
Thought putting in here there would of being someone who has experienced this with these stats before who then could of relayed a clearer picture for me.
Nevertheless, I appreciate all the replies
Yes that was my thought.
What I don't know is whether you can use the bus connection to the boiler (eg Opentherm or whatever) as well/ at the same time.
There are obvious warnings about not applying mains to the bus connections etc, but the on/off terminals are mains rated volt free terminals. See pic below.
That would have helped greatly. Perhaps Baxi installation engineers are sworn to secrecy!
It’s just a shame a Baxi engineer isn’t around this forum to help me out 😂🤣
I’m assuming it must have the capability to switch separate zones with the use of 2 stats, if not, they are missing out on the money 🤷‍♂️
If I remember correctly Baxi uses R-Bus and not Opentherm control, I believe there is a conversion module for Opentherm control but speaking to Baxi technical recently this is only available in a couple of EU countries
I suspect the answer is they don't know Baxi technical seemed very poor when I spoke to them a few months ago
That is a useful bit of information that none of my searches found. It looks like a stat and gateway would be needed for each zone and some research suggests the bus connections can be daisy chained
The problem is heating controls are evolving from the traditional on / off to the many levels of smart control which can modulate the boiler firing and optimise the heating profile to achieve the required set point at the given time and a lot of these controls are developed by third parties with little boiler manufacturer involvement
As I mentioned earlier recently Baxi seemed reasonable with their own plug an play system but dont get beyond the plug and play level when it comes to operating a boiler with a different control protocol they are lost
The wiring diagram Avo Mk8 posted suggests a gateway is needed for each zone valve overall the Baxi setup seems quite poor against some of the other smart heating controls available that can control individual rad valves and therefore individual room temperatures
DIYman123
Trainee
England
Trainee Electrician
Baxi Usense stat
Central Heating Systems
Thread Tags
Tags Tags
None
DIYman123,
UNG,
