I've found both Crabtree and Wylex very good quality and easy to wire - partly because they allow plenty of room internally. They're not at all cheap, but saving on installation time can sometimes offset the higher price. You mention MK; they also come into that same category of 'not cheap'.
And they have other fringe benefits e.g. they're usually less fragile than the cheaper alternatives - though that's not guaranteed.
One thing you need to be aware of is that occasional design changes, e.g. to the busbar, can mean that not all CUs are compatible with all MCBs / RCBOs, even if they're from the same manufacturer.
Another design feature to consider (if the user can agree to the significant extra cost of individual RCBOs) is whether the RCBOs have a switched neutral (sometimes described as DP or double-pole or SP&N). Not all manufacturers offer them, and they add slightly to the cost vs. single-pole ones, but they can make fault-finding much easier & avoid the loss of, say, half the circuits owing to an obscure non-obvious fault on an appliance. And thus sometimes avoid an urgent call-out from a dissatisfied user.
