M
monkeyelectric
Hey everyone! I don't do a right lot with electric gates but i've been asked to look at some. The guy has bought these new remotes from somewhere that will open the gates but only if you lean out of the window of the car with it in your hand which i assume is very annoying! Would an external antenna help this issue by extending the range and if so does it need to be the same frequency as the receiver in the control box i.e 315mhz?
Have you checked the batteries in the remotes I've had some that have spent too long on the shelf before now
Is there a socket to fit an external antenna? Yes, antennas should be matched to the frequency (usually 1/4 of the wavelength). Daz
I'm not sure if there is a socket from memory there's just a short length of cable coming from one of the terminals of the control panel! I'm going there in a bit to do some other work so I'll open it up and have a look then, I could just cut a longer piece of cable for it! :D
Wavelength will be 95cm so would it need to be 23-24cm long? Because I think its that now!
All it may just need is the antenna repositioning within the enclosure. Had a similar problem with the gates i fitted to our housing complex. Moved the short wire antenna to a better position away from mains cables and has worked perfectly ever since!!
Cheers Engineer i'll try that! I didn't get there today after but its the first job in the morning so we'll see
