My thought is that, for the mode of operation it is designed for, namely "bidirectional capability for PV, battery storage and back-feed installations" (their words) the input is L1 (at the top), so L2 at the bottom it consistent with its capability!there is something I do not understand. BG Type A bidirectional RCBO 32 A (CUCRB32DPA) has a L1 and N1 on top, load side and L2 on the bottom side for busbar connection. To me this is not logical as elsewhere e.g. on contactors etc.. L1 is normally input and L2 output. Any thoughts?
thank you, I had started doubting L2 should be connected to load sideMy thought is that, for the mode of operation it is designed for, namely "bidirectional capability for PV, battery storage and back-feed installations" (their words) the input is L1 (at the top), so L2 at the bottom it consistent with its capability!
To be clear, L2 at the bottom should be connected to the bus bar in the CU, as per manuf instructions, which I think is what you are saying. So for traditional house consumption (ie no generation), L1 (top) is the load side, but with full solar/battery micro-generation, L2 (incoming mains supply) becomes the load.thank you, I had started doubting L2 should be connected to load side![]()
