C
cakey
A customer has recently moved into hes new home and has a large shed fed with 2.5mm swa on a 80m run! Swa is protected by 20 amp mcb but the load at the shed end includes two 2kw heaters plus lights and sockets that he has been using and would like to continue to use. Volt drop calcs say he needs 10mm but typically does not want the expense and wants to know what effect the volt drop will have on appliances/tools he intends to use on sockets as it is. Guessing they will all run ok until the mcb trips?
