O
oldtimer
Was asked to look at a CU upgrade due to a plumber being called out he upgraded the shower to a 9 kw removed the existing 30 amp 3036 fuse for a 40 CB and then said to the 84 year old maybe best get an electrician to put a safety fuseboard in should cost you £300
So i said why is the plumber too busy to put it in himself ?????????? and does he always set prices for other peoples work ? so this is what I found.
1. Shower wired in 6mm pulls 37 amps cable clipped to the wall then thrown over the ceiling space 11 metres in total me thinks it needs upgraded to 10mm any comments ?
2. Main cut out at the bottom of the stairs CU in a cupboard upstairs about 15 metres away the supply cable is a 16mm micc earthed at the cut out end via a clamp but nothing at the DB side so do you run a seperate earth or clamp on to the MICC at both ends??.
3. No water or gas earthing.
Other than that he has been paid and I am the guy giving it I am sorry to tell you but......
Forgot to add the old lady was going to get a electrical maintenance contract for her energy supplier but the very nice man who came to see her scared the life out of her due to as he said the state of the DB
