Hi I just wanted to know if you have to use metal containment in a boilerhouse or whether I can use plastic thanks.
follow marvo's advice.If it's an existing boiler house I'd stick with the standard previously set so if there's steel containment already in there then stick to steel. If it's a new boiler house I'd enquire for a design spec. The decision is rarely just an electrical one, often there's fire regs etc that may determine the requirement.
thats minitrunking and gorrila glue is supposed to workYou can use plastic, but don't use sticky backed conduit, as it will fall down.
