Discuss Breakers upside down in the UK Electrical Forum area at ElectriciansForums.net
Bob Geldoff1234
Called to a house today to just change some switches and went to the mains to switch off.This is what I was presented with.IMG_20190313_115306777.jpg
If you notice all the breakers have been put in upside down.
My question is would they still work in a fault condition in that position?
Fuses and MCBs don’t care which way round they are.
Single module RCBOs can only be fitted one way.
Double module RCBOs and RCDs will operate if round the wrong way, but the test button may not.
Have you opened it? If the breakers are upside down it could be worth checking where the busbar is and make sure its clamped properly. I'm not sure if the top and bottom terminals are in the same position.
bloody obvious. the installer was australian. come on guys.it'snot rochet skienke.
Why didn't they put the main switch upside down then. If they wanted to be clever they could of installed 'em the right way up, but just put the labels upside down. Would of been quicker. :)
Reply to Breakers upside down in the UK Electrical Forum area at ElectriciansForums.net
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hi all. I have a power outlet that has no power coming to it. The breakers all appear to be untripped (I turned them off & on again to make...
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
