Hi all
can any one recomend a good cable/stud detector i have tried many and found all of them to be rubbish!!!
what sort of price would i expect to pay ??
Rich:)
Out of interest, which ones have you tried that are rubbish? I intend to get one and it would be handy to know which ones to avoid at least...!
Cheers!
I used a Bosch and i went straight through a central heating pipe buried in the wall,that was years ago thou.
even now when i drill into a wall i still wait for the hiss or the bang from the ccu i want a cable detector that i can trust some one must have one !!
i have a detector that detects metal, electricity and wooden studs. its flippin good, but is a bout 50 quid though. its made by a company called zircon. american i think.
hi smugley, my one isn't aa good as that 1! it detects the edges of studs only, that must be a newer model. i bought mine from ebay though.
Hi All,
Ref the cable detectors... If you look in B&Q , work with me on this one, they market two stud sensors that are actually made by Zircon. Ones black and the 'basic' model the other is a yellow one and all that is missing fro it is the brand name of Zircon. It's am edge finder (Zircon do make sensors that indicate the centre of studs) and has Zircon's 'DeepScan' facility to go to 38mm. retails at just under £18.
Regards,
Lofty.
What do you guys recomend now (since this post was a bit old). I am thinkin gof a bosch mdf 10 which finds cables, studs and pipes in solid and drywall (also claims to find non live cables) but is expensive at around 70 quid.
I have an old B&Q rapidtest (not sure if this was the one referred to above) which seemed to work ok if you gave it a good margin of error and used common sense but am lookin for something a bit better now.
thanks
Hi Andekoch,
The B&Q rapidtest is another one that they do and not the ones that I originally refered to. I also have looked at the Bosch one and as you say it's a bit pricey at £70 only to find that it's no better.
Thought I would bring back an oldie...
I need to get ahold of a wire tracer. I have metal shower rail with 240volts at it, with no obvious positioning of accessories in the area concerned.. So I am looking for a detector to allow me to locate or at least clarify that there is a live cable there. The fact that I can measure 240v from the rail to earth isn't enough apparently.
The budget is about £50, otherwise I'll have to start getting quotes, and purchase orders approved etc, all of which will delay this danger getting rectified.
I've asked the boy at CEF, useless as usual. I've checked out B&Q (as i have a trade card there) and they have 4 on there site. However the review for one of them comments that the live wire detection has to big an inaccuracy area...
Has anyone bought one for up to £50 that proves to be fairly reliable in this situation?
you're not leaving it live are you:)
clear the live condition by turning off mcbs
Err thanks for that.
:rolleyes:
I am leaving it live actually, it's the main house ring circuit that's now 'supplying the rail' and as Im unable to return till Thursday afternoon, I've left it on. I have however, locked the door to the room and kept the key with me.
ok- but there is an element of risk in your method
leaving the fault condition in place
sunny essex
cable detector
Electrical Tools and Products
tuckermot,
davelerave,
