Discuss cable shears in the Electrical Tools and Products area at ElectriciansForums.net
what cable shears/croppers are people using
Looking to buy a pair of cable shears for meter tails and such like, mostly 25mm sometimes 32mm so don't need to be ratchet or huge
Re: what cable shears/croppers are people using
I like the knipex 165mm long ones for 25mm etc
95 11 265
Knipex 95 11 165 under £25.
Will easily cut 35mm for anything bigger hacksaw/junior hacksaw is best
Rachet cutters are very good but not worth it unless you need them for confined space's or you work on larger sizes a lot
I've got a couple of pairs in the same style as that but with bright yellow handles and less than a tenner.
Nobody wants to nick them cos they're bright yellow but they cut through 50mm easy.
Reply to cable shears in the Electrical Tools and Products area at ElectriciansForums.net
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Thinking of getting a Runpotec XB300 cable dispenser, as my yellow framed tripod thing is unsatisfactory for all the usual reasons. You can...
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
Hi, thanks for reading this. Ive been asked to look at a job where the DNO connection (single phase 80A TT) is a long run to the final circuits...
