B
biggal5
Hi, Just wondering if anyone more experienced can advise me on my multi function tester? I've a Metrel Instaltest 61557 that I got a long time ago when I done my 16th edition... I stayed away from the electricians world for a while and then went back to do my 17th edition update about a year ago. I've got another multitester but I was wondering is it possible to re-calibrate my older Metrel 61557 tester and start using that aswell?.. It was barely used and in great shape and feel guilty about it just lying there!! Is it feasible to recalibrate and use again to the up to date workings or am I just wasting my money? If so does anyone know a good place in London I can calibrate it?
Thank You so much...
well i`ll let you into something now....my test gear will be at least 15-20 years old..lol..
still going strong...
nowt up with the metrel 61557...yes you could say its an obsolete modal now as its no longer in manufacture (having been replaced by the eurotest series)...but its still good to go....
crack on....
oh, and change the batteries on it wont you if its been stood....
Second what Glenn says.
A loop test is a loop test, regardless of what edition of the regs are out at the moment.
as above 2posts. ^^^^^. nowt wrong with old. look at me. LOL. :death:
Great, thank you all for your quick replies... I'll crack on and do that so. Batteries all changed already...
Thanks so much guys...
and dont forget as well...if you start getting anomalies on test results then be sure to check the batteries and the test leads first wont you before blaming the instrument....
batteries, leads and operator before blaming instrument
as to calibration, wait till a local wholesaler has a calibration day. you get it done at a good discount.
see what it is Archy is most older test instruments count up to 19.99 on low ohms...wheras the newer stuff goes upto 199.9...
not that it makeas a differance as lets say you got 5.0 ohms for a 6A b curve breaker on a domestic lighting circuit....even though it complies..would still send alarm bells ringing with me as it isn`t right...
the point i`m making is 19.99 max count on low ohms is more that enough....
and if a circuit is > 19.99 ohms, you have a problem anyway.
crack on....
I have, what i think is a Kew or Kyoritsu analogue ELI tester that must be around, or getting on for 30 years old now. Checking it against my calibrated Megger CM500 a few years ago, was still giving pretty accurate readings... lol!! It had not been out of it's case for a good 10 years or so either!!
Thinking more about it, ...it has 2 switch settings 1 ohm and 100 ohms, and has no batteries to fail either!! lol!!
well, E54 , it won't have batteries, will it, it's steam powered.
