B
BillyTheSparks
Got a call yesterday saying that their switch was on fire. I thought that it would be an over-exaggeration, and that it was slightly warm. I turned up to find this:
Lucky the MCB tripped off, as I believe that it had been smouldering away over the weekend.
The drywall box had completely vaporised and it had set the socket below alight, also causing that drywall box to incinerate and this circuit to also trip off.
What load did they have going through that third dimmer? Was it a 250w or 400w ratted? Good luck with sorting it out.
They was lucky not to have a house fire with that.
Blimey that is bad,i removed an old coin operated landlords meter last week and that was roasting hot on the top,removed henley block and you could pull the tails out without a need for a screwdriver,they even had the electric cooker on to make matters worse,you cant miss that smell of melting plastic.
Joking aside the extent of damage questions the sizing of cables as well as why the fusing didn't operate... is that a flex in socket!!!
The installation was in a commercial building, the third 'dimmer' wasn't a dimmer, just a push module. (Well what was left of it, it didn't look like the other two modules.)
The lighting circuit was protected by a 10a MCB
The 'flex' in the socket is actually FP200 (or similar.)
There was no intumescent protection within the boxes to stop the spread of combustion.
I'm no fire inspector so I'll never know what had caused this, possibly a loose connection, or perhaps a dodgy switch module? Nothing else comes to mind.
Thanks for the info.... Commercial install, what load is on those switches?
Going by the rats nest of red live wires at the back of the switch all bunched up plus the terminal blocks, that could be the cause as well? Keep us informed.
The loading was
7x 50w LV down lights - dimmer
10x 4x18w fluorescent fittings - non dimmer
The cables were all new colours as it was only installed 8 yrs ago. They're just red due to the heat. The amount of cables is due to all switches being two-way. So only 4 cables in total (3x 1.0 3core and 1x 2.5 t&e)
