Correct.So I'm assuming that the fault must have been on the outside circuit - evidenced by both the 30mA and 300mA having tripped - because if it had been on any other circuit only the 300mA would should tripped.
If you were trying to make an installation safer but did not want a lot of nuisance tripping then you could install a 300mA RCD as a main switch (segregation of circuits to prevent danger might stop this now). Rapid and backed up tripping on an earth fault.Still trying to get my head around why someone would have installed a 300mA RCD as a main switch ....
Most of the references in BS7671 are to an RCD and not to a specific mA of RCD.
It is only if you are aiming for additional protection (i.e. protection of persons and livestock) that you would need to drop to a 30mA RCD.
