M
murphyd
Can you extend cat 5 cable with connectors or just twist them, will it effect the signal
Twist, no!
You can make both ends off and buy couplers. They work but it's better to run a new cable.
The other alternative is to make the end off into a socket the plug into that.
You will need a pair of crimpers, and/or a punch down tool, RJ45 plugs etc.
I doubt it, the pairs are twisted together, in a specific format for a reason.
Some one more IT savvy the myself will probably tell you the ins and outs. But as soon as you get a lot of traffic dodgy connections will give you problems.
It depends a lot on the application. You can make twist joints and you can use connectors but firstly if it's a screened cable the joint area will be susceptible to noise such as RFI and EMI. Also depending on the quality of your joints your data transmission speeds may be compromised due to errors and noise and mismatched leg impedances etc. If it's on a 100 megs per second LAN or connecting to a telephope then it will probably be okay, if it's gigabit ethernet then probably not a good idea.
make ends into plugs and use a rj45 connector in between.
solder if you really have to, keep the length of un-twisted wires and stripped sheath as short as possible.
