Discuss catenary? in the Australia area at ElectriciansForums.net
L
lionelmcc
What kind of cable would you chaps recommend for power to a shed?
I haven't looked at the job yet and will use SWA if I can find a route.
If I have to go overhead what type of cable can I use withe centenary?
Any other options?
L
Hey Li.
You can use a T+E on a catenery wire, suitably sized for whatever will be in the shed. Usually a minimum of 6mm T+E is sufficient on a domestic premesis. SY is possibly another option, depends on the risk of damage really. I have also seen SWA on a catenary before now.
I also bond the catenary wire in 4mm earth and a line tap.
Cheers.
Yes.
On a small overhead between a house and garden shed say. I've seen literally hundreds of these particularly on farms, and confess I have used a T+E overhead on the odd occasion myself only on a span of about 2-3m.
Depending on the op's situation a trenched armoured is a far better job.
Reply to catenary? in the Australia area at ElectriciansForums.net
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
