Discuss CCTV- visually good in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
gazdkw82
Iv done a few cctv systems. Nothing professional, just the normal swann/hikvision stuff.
I have installed the cameras and respective cables in different ways. Some have been fed through the soffits into the loft, some have had JB boxes installed and cables ran through them and then rear entry into the building.
I am installing 8 cameras at a friends house next weekend. He has a 3 storey new build so lifting any floor boards and access to the soffit area will be difficult.
He has agreed that access to the loft will be tricky and has set up a corner in the study room to house the recorder and screen.
So, my question is, with 6 cameras scattered around the outside of the property (2 will be internal cameras) what's the best method of running the cables? Clipped direct? In conduit? Is there tricks to hide the cables? They are quite a small CSA.
I have decided to have a JB on the corner of the house and feed all cameras cables into that which will then lead into the house.
Any help would be appreciated
Mini trunking in the corner of walls. How are you going to get between each level?
Not sure mini trunking would look good outside?
I dont think we will go between levels. We are going to aim to have all cameras at level 2. Too high and the footage will be fuzzy.
The only camera that will be different will be the one covering the front door
Argh, outside. What is the construction of the outside walls?
Would have to agree with Buzz on the cat5. you could run 2 cables and Use the cores for each of the 8 camera's if your running local power to them if not then you will need more!
Reply to CCTV- visually good in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
My FIL wants a cctv system at his house, and normally i would just go with whatever kit was on offer at the time from t'internet. My own system...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
So can anyone advise me on our rights regarding security cameras in the UK. our house is detached and i have my own cameras positioned low so not...
Hi All, so I have a outdoor cctv camera that you plug in - I'm thinking of attaching this to the soffit and going into the loft from there (very...
Hi all, this one is for the cctv gurus Installing a cctv system with 14 HiKVision is cameras. 13 of which are via wireless bridges as it is a...
