Search the forum,
Discuss ck crimp tools in the Electrical Tools and Products area at ElectriciansForums.net
S
Sparky_Ben
Has any one used the above and how do you find them, looking at the larger set which will crimp upto 25mm un-insualted crimps.?
thanks in advance
Been told to look for hexagonal crimpers rather than indent, except maybe on trirated.
Friend got a nice set, upto 50mm I think, from Western electrical, compact enough to fit in tool box as well.
I wrote the part no down on a drill case but thats in the container, Ill see if I can get it for you on monday.
Davidco, Klauke also do em but they are around £100.
Indent crimp heads are good up to 25mm, 35mm and above i would always go with hexagonal die crimping. Ratchet hand crimping gets a bit like heavy work over 25mm, all of our crimper's for the heavier cable sizes are hand or machine hydrolic servo units.... Which start getting very expensive to buy...lol!!
Reply to ck crimp tools in the Electrical Tools and Products area at ElectriciansForums.net
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
Hi all, Got to look at a job where the builder has cut through the underfloor heating mat and it’s gone right through the heated cable. Not...
Hi All. Hoping for some advice please. I've severe arthritis in the hands (all three :flushed:) A large dollop of osteoarthritis but I'm also...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
