Discuss Coax help in the UK Electrical Forum area at ElectriciansForums.net
Wanting a hardwired coax for my tv, I already have a tv coax point but I want to keep this and don’t want any cables on show, now would the best way be run a Coax into the wall into the existing coax point would I need to add a splitter inside the coax point for the new coax?
I have existing coax point, now I’m going to run a coax from tv on wall through a brushed outlet now can I run the cable will be fixed inside stud wall into the existing coax point and join it inside the back box with a splitter?
Just run that by me one more time?
There will be a coax from the TV to the wall?
So that's a cable on show...
Reply to Coax help in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have bought a new house. It has coax cables running to pretty much all rooms. I would like to replace these with cat6, and install new face...
We have had RG11 installed in some flats for use with Virgin/Internet. It should I think have been RG6 but the guy at Virgin was insistent it...
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
