Discuss Component Din Rail Terminal in the Electrical Tools and Products area at ElectriciansForums.net
WallaceP
Hello, I am looking to get some din rail terminals what I can put a 500 Ohm Resistor in. In the past I have used ones like in the photo attached, I cant seem to find them online now. Can anyone tell me the correct term to find them on RS or any other supplier. Thanks
Thanks mate, I wasn't sure if the Diode that comes with this is removable tho.
I assumed they were, but didn’t read the info fully, wago ones are changeable, certainly if you get the right one, see link once a mod has approved it or google wago pluggable diode/led module ( also takes resistors,) there’s also fixed block version but not sure about that as it has other stuff built in
Reply to Component Din Rail Terminal in the Electrical Tools and Products area at ElectriciansForums.net
Hello All Has anyone come across a problem fitting the front cover on the Hager Design 10 board over some RCBOs and a Disconnector switch? The...
Hi, my CDA FWC303 wine fridge is knackered. The compressor doesn't start and I've traced it to the PTC which I plan to replace and have identified...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi I’ve recently got my first home I’m not entirely sure when they were built I’m thinking possibly 60s or 70s? My problem is the storage heaters...
