Even IP rated jobs can get water ingress tha will give you a low ir the only joint I would use underground would be the sealed submarine joints those ones filled with resin
they look dry, the back of the plug is sealed with resin and the front of the plug pictured is dry with no signs of water ingress, some other light fittings on other circuits we have seen water ingress and it’s fairly visible, I was getting voltage transfer across all cores, even the Dali side.
I can try and see if they’ll dry out and the IR improves but it’s been proven as a manufacturing defect as the plugs where installed correctly so new fittings and fly leads are needed to rectify.
