Sorted. I was tempted to say nothing and hide behind the sofa. I've been trying to think of a good excuse but I can't appart from old age brain fade. It helps if the wires to the keypad are connected to the correct connectors !. If I tried finding an excuse it would be about the printed instructions that came with the keypad. I know my eyes aren't as good as they used to be but you need an Electron Scanning Microscope to read. Yes I know, poor excuse.
Update and confirmation of connecting Sounder/Siren to Eaton Scantronic PAN-10W.
0 and 12 volts as normal.
Sounder/Siren Tamper to TR on main PCB.
There are three connections marked OP1 , OP2 and OP3 ( OP = Output ).
OP1 is connection for Sounder/Siren.
OP2 is connection for Strobe.
OP3 is a customisable connection for things like Internal Sounder etc.
I also asked if the Eaton Scantronic PAN-10W can be used without connecting Tamper or using EOL resistors.
The reason I wanted to do this was to save me having to fit EOL resistors to all the PIRs.
Yes it can be done but requires a lot of buggering about, easier and quicker to fit EOL resistors ( 2k2 and 4k7 ).
Hope this helps someone.
