M
Marvo
Yeah, just a thought. I see Phil's hijacked your avatar as well
Could be the length of cable run with 95 parallel cables. if a fault was to occur at the far end on one cable it may not clear the fuse within the 5 sec disconnection time due to the fault current being lower in a single 95 than in a 185 cable.
Good news then, sounds like he is flexible, the Job should go well, make sure you make him a cuppa if he visits site :clap:Update had an emailing confirming the parallel supply is acceptable and the drawings are being changed tomorrow![]()
Whats worrying is that we all had expectations that the performance of 2 beats 1, yet he convinced himself the opposite. Could this be his first design ?
BTW - just got on to the back of this thread and so glad of the outcome as i have just installed 2 X 120 as being better than 1 X240 ..... was worried for a wee while
Cant argue with the logic, but it would mean accepting an unlikely double fault scenario with the design
Thx, but its in and buried. Goes hot on Thursday.
