Hi all,
I need to convert a hardwire light into a plug socket 3 pin UK, as it’s seems like a bit of a faff to get someone to install a new cable into the brick.
How can I do this pls? I’ve seen a plug adapter on amazon which looks like it could
work. But I have no idea if the wattage etc is correct. Sundertech Plug in Adapter for Batten Lights, UK Plug with 2.8 m Cable+Switch+Junction Box for Easy Connect to pre-Wired Ceiling Lights, L+N only No Grounding Max 500W 9 FT Indoor Use: Amazon.co.uk: DIY & Tools - https://amzn.eu/d/bnSAJ76
The wall light is a: AC 220V -240V 50-60Hz
Many thanks
Harry
Many thanks
Harry
