Discuss correction factor for discharge lighting in the Australia area at ElectriciansForums.net
P
p11jor
hi guys, just a quick calc here:-
4 X 400w rated lighting, is my calculation for this
1600/230 = 6.9amp X correction factor
Type C circuit Breaker.
thanks
phil
Reply to correction factor for discharge lighting in the Australia area at ElectriciansForums.net
Hi all , The measured value of loop impedance for a circuit is 2.4Ω. If the temperature at the time of the test was 20°C and the cable is 70°C...
Need help check that my cable calculations are correct as still new to doing them. 6A Lighting Circuit 60898 MCB Type B wiring in 1MM²/1MM² T+E...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi little lost on a question for lvl 4 design verification Can anyone guide me to any calculations or formulas Its for a 4.35m x 2.8m plant room...
Firstly, thank you for taking the time to read this. I am not trained in electrics whatsoever, I am a just a home owner looking for advice. I...
