T
TF and the wire
Anyone know where I can find a datasheet or manual for a counter made by Electronic counters and control, a US company. Its a MU115A-1. i need to know the functions of the terminals on the unit. Tried Googling to no avail.
It is used to count sheets of cardboard coming off a machine and then to trigger a stacking cycle. The operator sets the number of sheets required using the thumbwheel. It has a digital display of the count. There must be a reset terminal and I assume there are a number of terminals that must be connected to live or neutral to program the unit for a particular application. I just need to know their functions.
Surely you can e-mail the manufacturer in the states and ask for a blueprint of the machines wiring system?
I have a good set of drawings for the machine, but they don't go into detail of the component parts such as these counters. I have to get any spares from the US via this manufacturer. I can't find anything on the internet regarding the manufacturer of the actual counter and the machine manufacturer has started sending an equivalent part, which is a different size and I have to make blanking plates etc. they are also quite expensive.
If I knew what each terminal did. I could get an equivalent part cheaper, quicker and easier from RS. I could have an educated guess as to what each terminal did by experimenting and working through the drawings but it would be a help if I had access to a datasheet.
Are there no markings on the unit? I can't believe anyone would manufacture a one off counter for a machine.
Heidleberg do just that.
One of these?
New Ecci Electronic Counter Controls MU105C 1 SP15 | eBay
It seems that they may be an old brand, these offer replacements of some models,from illinois as was ecci...worth an email
Schaer's Electronics Your Source For Controls | custom counters controls | ecci counters industrial counters controls | encoders proximity pickups sensors | custom counters controls | danaher control products dynapar veeder root eagle signal
