Discuss crimpers in the UK Electrical Forum area at ElectriciansForums.net
i have a haupa, similar to the first one, hex crimper, 6mm - 50mm, £70.
i just use my teeth.
first crimper is a "hex die" crimper
second is an "indent" crimper.
the difference is how they clamp the lug onto the cable....
for £50 i'd get the hydraulic set , much easier to use and comes with carry case and dies upto 300mm........
HYDRAULIC CRIMPING TOOL KIT CRIMPERS CRIMPER 10-300mm | eBay
The hydraulic ones are the way to go,they make life much easier as all the crimping I do seems to be in tight spaces.
I thought these would be a lot more expensive,at that price I would not be too sure of the quality.
Check out for the battery operated versions,I have used them in the past and they were great and saved so much time when you are under pressure in a shut down to get the power back on.
Agree!! Anything from 50 mm and over, and you'll be struggling in a restricted space with the brute force manual units. Indent or hex, it basically makes little difference, the die size will ensure a solid crimped connection...
Well at £50 the quality isn't going to compare with the well known makes, but i'm sure i've seen posts on here where others have bought this hydraulic crimper and have been pleased with it. So you pays your money and take your chances!! lol!!
Reply to crimpers in the UK Electrical Forum area at ElectriciansForums.net
Hi guys I have been tasked with upgrading some old rewireable fuseboards for a food warehouse that runs continually 24/7. I was asked to do an...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
