Spudnik
Hi fellas,
I knwo each job is different but roughly how much do you charge to change a CU (assuming main bonding etc is up to date.
Do you carry out a rough PIR beforehand or just hope that the rcd dont trip?:D
Me? around £350 for a cu swap, full cert, labeled, circuit schedule, notification etc.
And yes, i do hope for the best and test afterwards:D:D
Yes mate depending on the size of the board, somwhere around the £300 - £350 mark is bang on.
Myself, before changing the board I do a quick insulation resistance test because theres nothing worse than trying to switch on only to find theres a fault:(
It's happened in the past, but at least if you know about it you can pre warn the customer and explain what needs doing beforehand rather than finding out at the end and then telling the customer theres a problem because their usual response is "well it worked before you started fiddling". So you then spend the next couple of hours fault finding for free.:o
Thats my take on things anyway.
Hi Jason yep sounds good to me also ! I do quick visual and R2(wander lead) etc and make sure everything works first ! also do a sample 1 in 4 on sockets/lights to inspect.
Regards
Tony.
Hi fellas,
price sounds about right to me ;)
i normally base my pre change tests on age/condition of the property, but have steemed in and changed the cu on more than one occasion before :o:eek::o
