danhowell
Hi,
I am working on a spotlight track system that has 12 Edison par30 75w 240v halogen bulbs. it is fed from a 3 phase DB (400v) on a 10a cb and was installed less than a year ago. All but 3 bulbs have gone and it is reported that the bulbs went quite quickly. Any ideas why and how i might remedy?
Cheap bulbs mate (lamps for the more discerning members), I would suggest installing quality lamps!
Hi Dan
The only suggestion that I can come up with a "Soft start switch" or "dimmer" that starts off low level and is then increased to full power. But am I right in saying that the load is 12 x 30 x 75w over 3 phases ? If so it may be a bigger problem. I will Google on and see what I can find.
Certainly a soft start is much less destructive on lamps
Phil
Hi, the DB is 3 phase but the supply to the lights is single; sorry my original post was probably deceiving
