P
Platinum lad
Hey guys quick question had a look at a shower install,6mm t&e installed from db to 45a Pc switch in bathroom they've never had a shower but its been run for whatever reason it's black
and red colour I've done test cable is fine would this have to be removed to comply or would a sticker at mains suffice? It needs rcd protection also....regarding departures I'm abit confused light in bathroom is not rcd protected but I know regs aren't retrospective would this go down in comments on eic? Any replies appreciated
have you gone there to install a shower, or do an inspection?
There is no need to remove cable because its the old red-black, it's just the same material and if it tests out fine then put a bit of brown-blue sleeving over the top and sticker at the DB.
RCD protection can be placed next to the main DB in a 'shower protection unit' - or if you're not feeling posh, just call it a RCD enclosure - if the cable has already been run, hallelujah - saves you a massive ballache. (you don't need RCD protection when replacing like for like, but because theres never been a shower there, then you need it - some may argue because the cable has already been routed)
No to the light being not RCD protected, it's already installed and was satisfactuory to previous regulations.
