Discuss Dry lining boxes substitute in the Electrical Tools and Products area at ElectriciansForums.net
J
jasonmizen
Evening all,
was wondering if there's anything else out there rather than using dry lining boxes or the good old fashioned nogging when boxing up on new builds.
cheeres
I think he means rather than metal knockout boxes and dry liners, as pointed out there are surface boxes, but hey, who would want those on a new build
I think he means is there an alternative to dry line boxes for sockets in a timber framed house, other than putting in noggins and using metal boxes. That's my interpretation!
I've never seen any need to use anything else. I prefer to use galvanised boxes where possible, otherwise fastfix boxes are available just in case. I find both are as adaptable as I need them to be.
On the job I'm on at the moment the accessories are extra deep so we've been cutting away most of the back of the box and wrapping grommet strip edging around it so the accessory pokes into the void behind, then the boxes have been fixed into the panel using screws through the inside edge of the box. Not ideal IMO but it's one way of doing it.
if it's speed you're concerned about, use the round dry lining boxes. much quicker to cut out with a hole saw.
I somehow remember Ashley bringing out a range of boxes that were round ,that fitted into a 3" core cut hole
neat idea that never took off
only problem is that these are only suited to single boxes.
Reply to Dry lining boxes substitute in the Electrical Tools and Products area at ElectriciansForums.net
A first today. While sober and of sound mind I deliberately purchased some Axiom 45mm dry line boxes. I've found something they will do that...
Hi ive recently got myself a mig welder for my garage but each time i try to use it it trips out. Ive spoken to an electrician and he said its...
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse...
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
We have a customer in a large office block with all power in the building fed from an Electrak plug in busbar system. Lots of desks, lots of...
