IF 2mA is fatal then City & Guilds & EAL need to totally re-write their entire range of electrical qualifications, because I can assure you that students are taught that the fatal limit is 30mA, I should know as Ive worked in the learning environment.
but how long is long enough? 1 sec? 3 minutes? there's no set in stone rule. different bodies, different circumstances, don't think there's many volunteers to do real life testing.
QUOTE=david911cockbur;702238]telectrix - Are you actually an electrician?
2mA at a supply voltage of 230v is lethal if the duration of the shock is long enough![/QUOTE]
I suspect he is just a plasterer,he has however done a short course on rcd protection, so he knows lots about these sort of things
it's OK. i am an electrician, and a live one. my thick skin can take insults just as well as 20mA or so.
Interesting telectrix, but an American study from 1987. At a lower voltage and predating our own information upon which the EAWR is based!
I repeat; as little as 2mA at a supply voltage of 230v can be fatal if the duration of the shock is long enough.
How hard is it to release yourself from a 2mA current compared to a 30mA or 50mA current?, that is what counts
So who lied to the C&G and the EAL; and yes they do need to re-write there books if that's what they're telling youngsters!
I did offer people the chance to prove the point to themselves but got banned from this forum for a while for suggsting it.
Anyway, having given the Emma Shaw example some thought:
Metal stud partitioning is obviously made of metal, metal is a conductor of electrical energy, it is reasonably foreseeable that passing cables through metal stud partitioning could result in that partitioning becoming charged, so why wasn't the partitioning earthed as per Reg. 8 of the EAWR?
Earthing the partitioning at the installation stage would have prevented the affected circuit from being energised in the first place (until the fault had been rectified RCD or no RCD), the danger would never have arisen!
it all depends on the individual, I've had some decent belts off circuits under a heavy load and I'm fine, bit of burnt skin and a wake up call and a bit of swearing at yourself, It happens, in the case of the lady that died it sounds like as she was holding the wet mop in a puddl of live water which was in contact with the metal stud she gave the circuit a return path as she turned off the stopcock and that's how it happenned, I'd say that it was a fluke tbh obviously bad practice by someone but most people would have a belt and be fine it's not that many people who have fatal electrocutions of small domestic circuits but sadly there are some
plus you have a pretty bad atittude to somone so new to the forum, you need to chill out mate
Llan. there is a documented 'let go' current which I think might be 10mA from memory.
So I would guess quite easy. the problem is that the feeling is quite nice to begin with so kids tend to go back and try it again.
Sorry peter but false and misleading info. really winds me up.
You should have known me a few years ago when I was suffering with anger management problems. Now that all of my broken teeth have come out, my detached retina has been lazered and my skull has had a chance to be repaired, they are in the past thankfully.
sounds like your anger didn't do you any favours, just relax and chill into the banter dude, I still am certain that different individuals have different thresholds, if we were all that sensitive to electricity there would a lot more fatalaties related to electricity and a lot of dead electricians...we've all had belts avoidable or not, I had a belt off a light fitting once after the distribution board was isolated, they had knicked a feed from the shop next door and me being a numpty checked the isolation at the board and just assumed the circuit wouldbe dead
First of all f&r we're talking about a dead girl here so cut the sarcasm!
telectrix - 2mA is the lethal threshold, who told you it was 30mA?
None of which ACTUALLY gets to the point of how you drew your conclusions from the information you presented.
Quite apart from which also, while it may have been sarcasm, it also applies as a valid H&S point along the way - if this was not domestic. You don't give that information either.
Third - 2mA is the lethal threshold? On what basis? That's like saying driving a car is lethal. Defibrillators deliver far more current than that for one thing. So.... clarify. Where and when are you claiming 2mA is a lethal threshold?
Fourth - with only 11 posts under your belt, mate - best to cut the alpha male thing - it doesn't sit well in this forum with anyone. If it's constructive discussion you're looking for, then quote your sources, identify facts, and play the game with some respect for people who've been on the forum a lot longer. While clearly you claim to know Telectrix from elsewhere, none of the rest of us know those circumstances - so keep the personal out of it.
