I have two consumer units fed via henley blocks from the meter and 100amp fuse.
The original plastic cased CS from 2003 with 25mm tails. There are three slots available in this CS.
The second is a recently installed small metal cased unit feeding my heat pump and a small 2.4KW solar PV. This is fed from 16mm tails and also has three slots available.
I'm 'considering' buying an EV and thus having a 7.4 Kw charger fitted.
Can any potential issues be seen with the above?
