EV Charger - Tesla
Hi Guys,
After a bit of sanity here, I am in the process of my Part P installation cert, I am dabbling with fitting my own Tesla charger in my house, I would like someones words of wisdom and experience to assist me with if 'earthing' method is correct.
My house runs a TN-C system, Tesla chargers do not come with any Pen or overcurrent protection, I do not have space to fit a Pen Detection device as our fuseboard is located under the stairs in the most awkward place ever!! even weirder on a new build.
I am thinking of running a dedicated earth 10mm run to a 1200mm earth rod in the garden as my fuseboard backs onto the outer wall so I could run it the other side of the wall and straight into the Rod, is this a good solution if I cannot get a pen device fitted ? therefore the Tesla charger would have its own dedicated TT system ?
Thanks in advance.
Nothing wrong with doing that, probably needless to say but when you go TT island mode you just need to make sure TN system earth and TT earth do not come into contact or even bridgeable, ie say an external water tap and the car are at arms length where someone could touch the car and the tap with arms out. Main thing is isolation of earths and of course the correct RCD upstream of the charger.
The only concern I'd say is probably the distance to the rod in yer garden and the loop impedance. Rods are pretty poor unless multiple rods of great lengths are deployed at the right distance from one another. The ideal method is to have the rod right at the charger, if you can or can get someone in to install a rod at your charger, I'd advise that mate.
Hi Guys,
Thanks in advance.
For £100 you can buy a Salus with built in 6mA DC protection and PEN fault protection. I'm not recommending them as I've never fitted one, but there are many options over the tesla.
the only Tesla charger i ever fitted required a type B RCD, which was big and very expensive. Does the Tesla charger have built in 6mA DC residual current protection?
Hi Guys,
Thanks in advance.
Presumably TN-C-S - TN-C is illegal in the UK.
