cliffed
Just your thoughts on this one,extending some extra power points in offices,any problems coming off existing trunking ,conduit system with t&e 2.5mm.To be more precise,connecting onto 2.5mm single cables off ring man,with t&e cablng in a suitable enclosure,or condut like to like,easy to t&e at this stage cheers
Make your question out in proper sentences and it will be easier to understand. I think I know what you are saying and yes that is ok. But surely if you are doing this work you don't need to ask such basic questions
So you want to make a joint inside a trunking is what you are saying? That's fine, just don't use Choc blocks.
Why not use singles? 2 x t&e in 20mm conduit is a nightmare (assuming you are extending the RFC)
Also you are reducing CPC size if existing is 2.5mm
Bloody silly question in this modern era, but what is wrong in following the existing installation, instead of B******ising it with an inferior extension installation??
