A
assegayer
Okay guys this has been bugging me for a while..
What im thinking is that if you fit an FCU say on a cooker circuit to power a hob igniter (just an example) you would say put a 1amp fuse, how does this even work.
i mean wouldnt you still be getting like 40 amps from the oven going through the flex coming out of FCU therefore melting the flex because it cannot take the ampage? and then sometimes i hear different things from different people one person will say the fuse protects the actual load the next person will say no it protects the cable????!!
or does the FCU just simply take the amp it needs when it needs it?
i hope this is clear
thanks
thanks
