Discuss Ferrule/bootlace Cu in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
iv just done my first ever CU board change. I had a qualified electrician with me. Now its all in and tested I want to tidy the terminations up abit and dress it up more. I was thinking of doing ferrule crimp/bootlace the conductors but im unsure if its bad practice to ferrule/bootlace solid conductors as apposed to stranded?
Also are the ratchet type crimpers better used?
Do you think it offers an advantage to fit ferrules to the solid cores? Also, bear in mind it adds another connection which is a potential weak point unless done correctly. Daz
There is no need to ferrule a solid conductor. They are not designed for such a task anyway. It would only offer the same strength of termination as a single solid conductor under a screw terminal. This would obviously not be as good as a properly doubled over and positioned solid conductor.
If you are thinking of aesthetics over mechanical and electrical soundness then you thinking about the job back to front.
No. Mechanical and safety comes first!
Reply to Ferrule/bootlace Cu in the UK Electrical Forum area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
We often see folk asking about which crimp tool to buy/use so I decided to round up my collection and put them to the test. Ladies and gentlemen...
10K
At work in our main kitchen, the 6kW (26A sp) water packed up. The restaurant staff were in turmoil, as they had no hot water to make the tea...
I've come across a DNO installed (SSEN) 3 Ph 3 core PNE supply cable from a private substation to a large Lucy domestic head. Cable 3 Ph is copper...
Doing some testing today on a Wet Room installation. Fed from its own small CU. And consists of 2 x seperate 50A (for 10.5kw shower) circuits...
