I need to buy a whole assortment of Bootlace Ferrules for commercial work, I know this sounds pedantic but which colouring system is most prevalent on big commercial / industrial sites: The DIN 46228-4 (which I used in the States), the French NFC system or the Wiedermueller system.
G
I would say it is the French system but it doesn't really matter.
The ones that fit best!
Its odd that I've found from one system fit well on a particular size, whereas not so well from another system but then with another size cable its the other around!
There doesn't seem to be any standardisation on the sites I work on (power stations). As said above, seems to be a case of what fits best.
Tonful website, mainly aimed at designers/ manufacturers, has a few suggestions, including that use of the French standard is surprisingly common in the UK:
