Please come check out EFbot; Testing thread is here. Come see what it can do. . Tag it in any thread using @efbot you will need give it a few seconds and refresh a page for it to post a reply post.
Came across a white backbox with plastic clipped out to let the 2.5 twin and earth enter from above. The small gap was not filled ( I usually fill it with silicone) . Dawned on me that I’ve never seen A recommendation on what silicone type to use or is there a better way?
uf it's a surface pattress, i usually fill rhe hole if it's oversized for the cable/s. IP4X and all that . decorators'caulk is cheaper than silicone and does the job OK.
Never had this problem with a surface pattress , if your careful with your knockout just about get the 2.5mm in nice an tight. Would white mastic do the job.
