Colin33
I've only ever used the standard 25mm meter tails. What are the 'flexi' tails like to use? Do they tighten up well in the terminals or do they need crimped ferrules? I've an awkward 6m run to complete and considering the flexi version if it'll make life easier, any advice welcome :-)
My local CEF only has the flexi tails in 1,2,3 and 5m kits… not “off the drum” by the metre.
Will be more expensive than standard 7 strand, and a ferrule may be needed depending on the style of termination.
I buy the flexi tails in brown and blue on 50m drums. works out much cheaper. Usually from CEF.
Having worked with both, I really can't see why people like the stiff and hard to work with 6181Y.
In the past when I tried to buy 6371Y locally, I had the wholesalers basically asking "why would you want that, EVERYONE uses 6181Y". IIRC CEF had it to order, but only in BT DC colours (was that blue & grey ?) - not brown & blue.
I guess the same people who see nothing wrong with 6181Y are the same people who wonder why anyone asks about stranded 2.5mm T&E.
You'll need to crimp the ends, 25mm pin lugs
I don't see why they are not fine stranded. They are going to make a far better connection into a clamped terminal than the more rigid conductors.
