L
Lex
hey guysCould do with a bit of advice. I'm working out in the middle east, in a building of 20 or so offices, in two of the offices random flourescent lights have started to go. when i've removed the defusers i can see visible scorching of some of the cables and the ends of only some of the tubes. replacing the tubes does no good. I'm looking into changing the balasts, but im not sure if this will help. It bothers me that its just these two offices that are going. they are on the same circuit, but there are another 2 offices on the same circuit and they are fine. the current ballasts make is frater, ive been using osram tubes. they are always very tight to fit in. could it be an issue of incompatable components? Unfortunately I have virtually no experience with flourescents and would welcome any advice you guys can give me. ThanksLex
i worked in saudi amongst other mid east places
we found the expelair fans were spinning much too fast then burning out
the reason was the electrical supply was 60 hz(not 50 hz as in the uk)
this was before electronic fluo,s were invented, if the fluo,s are electronic that may be the prob
a quick story, i did the electrics in a new dr-g/medicine storage depot/office block in aden
the supply for the whole area came from a generating station the the british army built in about 1960
the voltage used to drop from about 220v day time to abt 170-180v in the evening
all the fluo,s in the warehouse(200 or so) used to get dimmer and dimmer then fail
just after that job there was a war and we were all evacuated -- great fun
