I
iamelectric
any you guys on here have one of these , wondering if they where any good
if you dont know what it is , type it into youtube , i cant get a link up
Product @ Gekko gripper
this one? just looked at it, it may be good for a 15mm plywood, but for a proper uk victorian floor it will give next to none of grip. unless you got an industrial magnet in there. when you have it under the floor and it looses the grip the underneath bit will fall down and you need to repeat the operation? or it may get tangled with cables and pipes and you wont get it out...
super rod does that job better imho.
played with 1 in cef
not 100% sure on them have rods so not really much point think they where 20 in there
Interesting product.
Couple of problems I can see:
You need quite a large entry and exit hole (bigger than when using rods).
There's some risk that cables will end up lying on top of heating pipes rather than passing underneath on the surface of the ceiling.
I still use my metal coat hanger taped to mini trunking lid the best fishing wire or tape cable to top of trunking lid and push through your void to point, the old way is still a good way.
There's some risk that cables will end up lying on top of heating pipes rather than passing underneath on the surface of the ceiling.[/QUOTE]
good point i will say that and see what they say
Meanwhile in the real world.
Got a gekko gripper from cef. Must say that at first I wasn't convinced but now I'm using it most days. It's a real time saver too!
