here Ben....
images
images
I'd second nuts and bolts, but you will need a helper on the outside! Or.... put your fancy new mask to good use and spot weld them on through the screw holes!
Tek screws drill in, note how much protrudes, back it out, cut off excess, you now have a hole that has already been tapped by the original Tek screw, now reinsert and tighten by hand ( nut driver/ socket set) don't use the drill/impact driver as you will strip the original hole.
Ben
Nice one lads, some food for thought there, i was keen on the "chemical bonding" because it would just make for a more aesthetic job, not that it is really an issue they are just storage cabins at the end of the day. Didn't really fancy anything protruding on the outside of the cabin, but i have always been a big fan of nuts and bolts, know you have a solid solution that way.
I think ill glue the trunking and fix the accessories with nut and bolt. Seems most sensible solution.
Thanks chaps, happy Friday to all.
Maybe I'm being thick but why are you using mini trunking etc in this kind of environment anyway? Surely conduit would look a whole lot better along a corriguated edge, and you'd have less problems with your fixing conundrum.
As it stands, I'd drill it, put some short screwhead bolts in from the outside, and washer + nut them inside your enclosures, sticking a rubber washer if your outer side is outdoors. Foaming and gluing and all this is all well and good when something's going to be made good afterwards, but I fear what you're planning is going to look a right dogs dinner.
I'm assuming you're going to be using metal back-boxes, mind.....
Yes metal boxes. I was going to use conduit, but because the corregation is about 2 inches wide per ripple, i figured 2 inch maxi would just look neater? I guess its the whole angles thing. I've bought some TEK bolts and rubber seated washers now and will fix from inside out and grind away the excess.
I think if im honest, the whole glueing thing was just an experiment considering the minimal amount of fixtures i have and figured if i could do it neatly without gunging the place to bits, i could get away with quite a tidy, non intrusive finish.
I think the riveting idea is a very good one,won't be coming off anytime soon plus rivets are easy to drill out if you make a mistake.
So many possibilities....and no one else cares but me.... reckon ill just get the double sided tape out?
Dot and dab, mate. Works every time.
Ben, there’s a constant theme to you’re posts, “I’ve bought the gear, what do I do with it now.”
Please, ask first, then order the stuff. It makes everyone’s lives easier.
I’d have gone with the unistrut idea, with roofing bolts, the heads on the outside.
How are the corrugated sheets fixed to each other? I'd probably try to fix the accessories to the sheets the same way if possible. I'm guessing they used roofing bolts...
